Sunday I was riding in some low snow conditions on my way up to the higher zones. It was warm out, with saturated/weak snowpack. I got stuck often enough (thin snowpack over lots of deadfall) that the sled was getting plenty of cool down breaks. I rolled it out maybe 6 times. Later in the day, a few times when starting the sled to get going again, it would run rough and display P3000 on the gauge. A couple times felt & sounded like it was running on one cylinder. Blipping the throttle would clear up the rough running. If I shut it off and restarted it, the code was gone. Whether the code was active or not, the sled had a hesitation or sometimes a full on bog around 5000 RPM that it normally does not have. Once passed that RPM, it ran completely normally, taching at 8150 RPM at WOT and pulling hard.
I can't find much on this code. Came across one old thread on Arctic Chat about a Ctec 6000 having that code but no clear resolution was posted. Based on how wet the snow was when I was rolling out of stucks, I figured its probably water related.
This is on a 2018 Mtn Cat, about 1600 miles. New primary clutch and belt, stock clutching other than 68g weights. Just had the secondary off to clean/inspect, all good there. New plugs at 1200 miles. Updated upper intake & entire intake very well sealed. Has the Silber NA tune and a Bikeman Y-pipe. Stock muffler and pipe. TSS unplugged in the throttle block (maybe where water got in & caused trouble?).
Any ideas?
Any ideas?
