Prepping two of friends sleds b4 we head west. Using team alignment bar. Ur sposed to push it tight to outside of outer sheave on driven an then measure the clearance to the inner sheave on the primary. I find it tricky to get in there, and the primary is radiused where ur supposed to measure with a feeler. So i do it in reverse.
I push it tight to inner sheave on primary, tight to the leading edge of the outer sheave on secondary, and then measure the space b/t the bar and the trailing edge of the outer sheave on the secondary. With a little math i figure that space should be about .035 or .040
Both of these sleds have a solid .25" aka a quarter inch! Have u guys seen that? Gotta remove both thick washers behind secondary, and maybe put one skinny one back. Should be close. Just makin sure.... havent seen em this bad b4.
![uploadfromtaptalk1424657013856.jpg uploadfromtaptalk1424657013856.jpg](https://www.snowest.com/forum/data/attachments/201/201910-56c73cf1d3ab1e40ed1b8bc5ed52b6b0.jpg?hash=Vsc88dOrHk)
