If you knew how these modern day cheap oil filters release pressure to keep from blowing off cold starting you might think different.
Once they bypass the oil it is no longer forced to go threw the filter.
At one time you could purchase disposable filters for the vehicles that had pop offs, so when the oil thinned from a cold start it would be forced back threw the element.
Many named storm deductibles are set up as a percentage of a home’s value – usually from 1 to 10 percent – instead of a fixed dollar amount. That means a homeowner with a home insured for $161,100 would shell out $16,100 if their named storm deductible was 10 percent. If you’re not financially prepared, it can be a big sticker shock. Some insurance companies make the percentage deductible mandatory for homes in high-risk coastal areas.
