Bought many things from Burandt over the years. Always been helpful with knowledgeable solutions.
I bought his newest Maytrx 850 clutch kit that included:
Primary Spring (no secondary)
Helix (cut to his specs)
Roller Bearing
SLP Magnum Force Weights (adjustable from 60 to 69g)
SLP Secondary Rollers
I sent this with my stock clutches off to Patrick's Customs to get lightened and balanced. He installed the kit before preforming the work. I have 67g of weights in clutch weights now.
I didn't put 1 mile on the 22 Matryx Kaos 165 Slash before doing this. So I have no stock clutching reference to compare to.
I have 75mi on the sled and it still is only half way through break in mode. I ride at 5500 to 9000 elevation with most riding in the 7800 to 8400 range.
I just recently got the TRS tool and adjusted to TRS spec with the lightened (shaved) clutches from Patricks work. Will ride today for first time after doing TRS adjustment.
Wanted to provide all this info before asking this question.
What is the boards thoughts, recommendations, or experience with the Burandt Clutch Kit? I have no idea what the Primary spring weight is (his spec). I have no idea what the ramp or cut is on the Helix (his spec). All I know is Burandt does a lot with these sleds so I want to trust I am buying a product that makes the clutching better.
I don't have a solid opinion yet of the sled and clutching as it is still in break in mode and I have only ridden it in fresh deeper snow conditions. Today will be my first ride in harder packed snow.
Roller Bearing
