I never had any issues last year. I just installed the tiki for insurance
This guy should put the driveshaft and coupler back to sled and see if there is wobble then. Bearing will keep the coupler in its place and it is solid construction when drive shaft is properly seated and bottom gear is secured with circlip. Ofc theres little play otherwise, it normal you cant make fitment too tight.
On other video he also sells his own oil for the chain case. Most likely its just atf on expensive bottle.
If the driveshaft was in the sled and installed like it should be and it had no wobble then there would be no need for a product to fix the wobble and this video and his product would be a moot point…
Yeah its hard to prove something that doesn't exist.
If you open the chain case and measure this "wobble" when bottom gear is on, there is probably less play than on the crankshaft. If you take your clutch off and measure play on the end of your cranck, I promise you will be surprised how much there is. And that thing is spinning +8000rpm.
I look at it this way. The places we drop into and you’d never be able to pull a sled out. It’s pretty cheap insurance, even if it’s just for my mind. I also add a skid plate. If it really needed one, BRP would’ve installed it, right?
It’s everyone’s choice to customize their sled to their liking . If you want to run it do so if not don’t bother. I personally dont want the 2 piece shaft it has no purpose on my sled if I swap my track I’m going in the chain case regardless to service and inspect components. I also think some people don’t like to be wrong in an argument. When it’s your own sled it’s not wrong if your satisfied.
I agree we’ll over 90% of stuff is snake oil and for a majority of riders the sled is fine out of the box , i still believe the old solid shaft that was proven for 15 years is what the sleds should have
.if so I believe this topic would never bin started .
Also remember the tki is advertised as a fix kit kinda like the Polaris 800 cfi (fix) kit peps bought millions of them kits over the years .
Guys in business are always looking at things they can market that’s what progress guys do . Driver I remember reading you have run a jaws pipe on one of your old sled ? What was wrong with your stock pipe see what I mean you most likely got sucked in on the hype of the magic pipe ,
I believe the tki will help but not the ultimate fix , with this new chain and gear maybe not needed at all ,
Just give me some snow so I can ride these things
like i said previously, give tom a call or email him instead of assuming he is wrong or just trying to make a buck. he told me some interesting things regarding doo's r&d on the two piece driveshaft and maybe he'll share that with you.Its interesting to test stuff, nothing wrong with that. Stock pipe works good and jaws gave some extra. But I would never say you need it.
I don't think your comparison is on point at this matter. TKI makes claims that they can't or don't want to prove and they are showing only what they want to show. But we can prove Jaws claim on dyno any day.
