D
Driver
Sprocket is the same design and material, just a different cut for the chain
The process that the sprockets are made out of, are the same. Same material, the same holes etc. Regardless of the pitch of the tooth that cut on the OD of the sprocket. That’s what he ment, they are built the same, and the same design that been used for years.
Now doo went back to the machined solid steel bottom sprocket, same design but not tooth cut that came on the T3 and early G4’s.
Top post says that 2020-2022 turbo parts are the same as 2023 backing up the previous claim that the fault must be in the split drive shaft. But even if they are made the same way doesnt mean that they same level on strenght. Yeah I get it cast vs machined, but there can be good quality cast parts and bad quality cast made parts.
But yes, its good to move from cast bottom gear to machined one. Will be stronger for sure. But there was never problems with BW bottom gear 2020-2022.
And important thing to remember is that 2023 Turbo R chain & sprockets are downgraded big time from 2020-2022 turbo. Thats a fact...
