Here is what I think I know from previous experience. Pipes are generally built based on the air volume from the motor they are designed to run with. Basically speaking, if you are trying to pump more air in with your larger displacement, how can a pipe, designed for smaller cc's be efficient? Just saying if the slp pipe was built to perform on an 800 cc motor, why would we assume that it will work as effectively on a 900. It likely will work, yes, but I would guess you are leaving a little on the table. And why was the SLP such a failure on the other big bore and works so well on this one for others. Perhaps it has something to do with the port timing being different, sending different charge waves, at different intervals, I don't know. Just wondering if anyone has ran a pipe, actually designed for the larger volume of air? I can tell you that heat soak was an issue for me with the exact same pipe. Worked great at lower rpms, and for the short pokes, but hold it wide open for a good pull, and it would drop off.
Not the same motor, I know, but might have some relevance. But then again, if it is only a few people who are having this issue, then forget the whole thing and lets look at other possibilities like the clutches, fuel delivery and pipe temp sensors.
This theory is only based on what I think I know, and how I interpret it. I take corrective criticism as good as anyone, so please enlighten me. I just want these things to......not rip, but better.
