idle set
did a bunch of changes this year, so i'm looking to figure out my jetting,
question is: without turbo hooked up (pressure pipe not installed) i set my idle so it's just about right, not too rich, consistant 1500rpm. when i install pipe idle rpm jumps up a bit and i'm rich, backing out on the thumb screw actually makes it rev more, screwing it in lowers rpm! am i having some of incoming air at idle being forced through the idle circuit and it's relieved with the slide open a bit? should i install a softer spring in the bov to release as much air as possible at idle?
800 big block w/900 engine-tech kit
55 pilots, seem hugh should i try smaller
145 starter jets
420 mains
1 1/2 turns on idle screws
2 turns on air screws
aerocharger 53
