We got a intake that will work for ya. Will sell any part you need.
What is your fuel pressure doing when it starts to do this? Is it consatant or fluttering?
what is your pipe pressure also?
These are the things that i have seen cause this over the years
not enough weight in the clutch
not enough air
bov spring to light
pipe pressure to high caused by to small of inlet pipe or down pipe or max out cfm's
injector timing off
head design.
hope this helps
Just measured my intake for the filter, and it is 3", odd i could of sworn it was a 2.5" intake, but nope its actually a 3" intake, i cleaned out my pre filter and its looking much better now, so hopefully it does the trick,
dont know fuel pressure, or pipe pressure, but im thinking the whole, intake restrictive, causes turbo to work harder to suck air, exhaust flows less, back pressure increases, charge temps increase,
i know my intake wasnt sucking, and this stuttering has been a issue getting worse and worse, my charge tube felt warm last ride, usually its always cool, and i know my 1st 2 rides where sled ran 100% perfect that charge temp was always nice and cool to the touch even after a 10 sec pull or 15 sec, then it started to go downhill,
i do plan to get a fuel pressure gauge but i dont see that happening this week now sadly
, and i will give yeah a call if need be bryce for sure
and my blow off valve, was giving me issues i was getting bog and stuff before, i had to return to idle basically for it to kind of fix its self, i havent had that issue yet now that i put a spring in it, more of a home made one as the one it came with was certainly too stiff
also i look back to this video, like i said earlier my 1st 2 trips it wasnt the snow that was coming overh teh ood so filter did not get snow on it, also that was the 2nd time filter ever been used so i would hope it would not of been plugged up yet....
at 1 min in looking at that vid, you see boost comes on fast, hits hard, pre filter does not look like its being sucked in at all, its flowing very nicely
http://youtu.be/-9EydbG3lG4?t=1m
