can i put a double sled deck on a 05 avalanche
The sportrac seats 4 don't it? why don't you build another deck over the roof, you know to balance the load, then you don't even need air bags! You can easily attach the front to your bumper!
Just got to thinking about this set-up. Do you have a set of sled dollies sitting around? I would just duct tape the ski tips to the rear bumper. You would have to use a lot of tape to make sure the sleds stayed right behind the vehicle on the curves. Then duct tape the dollies to the sled. You wouldn't want them to fly away on any big bumps along the road. Make sure you use the good duct tape. Some of that cheap stuff doesn't hold up too good when it gets cold.;)
Honda Sledeck
Why build a deck? Just get a large round of firewood and a couple straps and you'll be fine.:)
Couldnt you just jack the rear end up by the bumper and then weld the shocks solid? then you wouldnt have to worry about rear suspension sag, thus eliminating the expensive axial drop while saving untold amounts of weight.
just a suggestion
AHHHHHHH somwbody stole his thunder, but in MN you would be towing a iceshanty too.
hambone if that is your rig you must of been laughing your azz off reading this thread. i knew it could be done, but you dont have dual exhaust. you have the thingamijigger going down to the hitch just like invisioned. i see you just become a member so you could show off your masterpiece haha your lisence plate confirms it's. LOL
The "thingamijigger" is mostly just for loading. The weight is still over the back wheels when sleds are up there. I have the airbags in the garage, just haven't made the time to get them on. Yep.. I get the crazy looks...
Na, just lag bolt a 6' long piece of stout plywood to the bedrails and run 3" drywall screws through the skis ;)
Hamm,
It looks alot better than I thought it would. IF I owned an avalanche, I may consider letting you make one for me. You did good.
avy sled deck
simply (modded) a sled deck.:D
weve all modded a sled a time or too right.
are caregiver drives one of those,saved the pics
alumminum would be lighter,single dad takeing the 3 kids sleddin Hince the car seat on the summit
nice job
Sled Deck
Take video - America loves carnage!
Make sure you run P245/75 R16 tires load range C
Contact Darwin Awards as they will want your post-humus story!
