Can any one say pine cone CRUSHER!!!
i seen one just like that heating the trail 2 weeks ago. doesnt look as good without the 5 foot flames coming out of it! lol
Old School does'nt needs my help telling you that, you are bad Johnny. Old School has a sweet new sled and YOU are the one trying to burn him down.:mad:
By the way that is a MCXpress REAR mount which is much less likely to catch fire.
Old School, do you have a check value on the oil tank? The value will prevent the engine oil from pumping out if the motor is running with the sled up side down. Bacause your sled is fuel injected it will just keep running (no bowls to empty). The phazer is such a differant chassis, you will probably tip it over while learning how to ride it.
Have a great season
Have fun with it bud! Nice a-arm guards, alittle different but they look like they will work
Can you explain?
I will tell the little I know. Dee and Trey at Altitude Boost are the ones to ask (I called and left a message asking for more info).
Especially because the new Apex, Nytro and Phazer are fuel injected and will keep running even when NOT setting upright, it is important to prevent the engine oil from pumping out of the oil tank through the breather tube. There is an after market value on the breather tube that remains open during normal operation but closes if the sled is tipped over, preventing spillage.
This info is subject to revision. I will give more details after speaking the installer.
Thanks for the info alrevedup nope there isnt a check valve in there at the moment wasnt even aware that one existed, i do plan on putting a tether on to shut the sled off in the event i do tip it over to prevent an oil problem. but you are right and if its to far verticle you can loose it out of the turbo as well. Is there a turbo specific air filter with out the gauze to prevent filter freeze up?
need to call trey on his cell. He is in AZ playing with this MCX Rhino.
Sorry for hijacking the thread.
How does a guy from Lakewood know Trey?
There is a chance I may ride with Dee in Wolfcreek this weekend. Are you in.
By the way the snow really sucks up there;)
I was told, they will not run without oil pressure (ecm cuts ignition), but will start, then shut back off, if it doesn't sense pressure. I think they will run with the low oil light on. Two different circuits.
sorry to detour, nice sled!
Old School, I don't know about the filter or the ignition circuit. My nytro will run upside down until I shut it off.
The more I think about it the more I am not sure I understand. Are you saying there is a air filter other than the prefilter on the snorkel? Looks like you have a K&N prefilter, MCX also makes one just for the kits.
Correct there is a pre filter along with a 4 inch k an N Filter with wire and gauze/paper material and the guy i bought it from mentioned it will some times freeze.
kylie since your air filter is snorteled you should have min issues of freezing. just need to knock off the snow from time to time
Trey and Dee did my MCXpress Apex. Old Schools Phazer was the demo sled for Mtn Tech Yamaha and HA boost. I actually found this T-phazer for oldschool :). Wait till you see the mesh hood Trey has for his Nytro. Sweet
yes snow sucks up here. Actually heading to CB for the weekend :)
We'll have to meet up one weekend
Ya that does make since with it being elevated,
PJtheMunchkin What part of Colorado are you from, Kyle? Nice sled, BTW!
Im in castle rock-10 mins south of denver and ride with yammerhammer/Jim a bunch. Sounds like we might meet up Monday.
Thanks Man waiting for the paycheck to pick a jack up from you along with some sled mod stickers.
Who did you buy the Phazer from? Who put the turbo on? Just wondering, cause my little bro works at the South Xtreme store. He is pretty good, has done a couple of turbos for the Yammies!
Mountain Tech Yamaha in Nathrop CO (719) 395-0438
It was a demo sled from last year but still considered new to yamaha the kit was installed by the owner sean and with help from High Altitude Boost in salida. I Picked it up Tuesday.
Did you buy the extra 2 years of service with your sled. Thats 5 years in all.
Even with the turbo on it, its covered.
