A
Arctic Thunder
The boost it box is more exact on fueling than the attitude, I had no issues after really long pulls seeing any lean af #'s on mine. It just flat out runs very well. It exceeded my expectations of how I thought it would run before I installed it.
Ok, so
Explain this more, because I am still confused if the boost it box again is ONLY adjusting boost fuel how does it add fuel to the stock fuel map for the lean condition when you back out of the fuel after a pull?
Or how do you adjust fuel for the standard lean spot just prior to power valves opening?
To be real honest I am about done reading my AF guage unless it is under boost. All the other times it is just all over the place and I am on the stock fuel map so I shouldn't even worry about it.
Thunder
