I
INKEDRIDER
ACCOUNT CLOSED
Sounds good terry Ill give you a call.
Yes everyone that is running a Dobeck is struggling with the PRO but I still believe that it is all in the head!! I do not work for Dobeck but, have you ever watched the show top gear, I am the STIG.
It is absolutely NOT in the head. It is in the way the stock ECU controls the injectors. Conventional control boxes do not manipulate the injectors properly. The new Boondocker 3D programming does! This new programming is also based on PSI, RPM and TPS, simultaneously, to ensure there is no area you cannot tune. The 3D tuning is using only the stock injectors, not activating the auxiliary for now and we are able to exceed 10 psi on only the stock injectors. We have a ton of work into putting this programming together, and I WORKS. So if you have a Boondocker turbo Pro and have not had this update done yet, get your control box into us, we will reprogram and return ship your control box the same day we receive it.
http://www.boondockers.com/turbo/prormk.html
Junior
Junior
Very interesting and informative, I find it incredible that, a 214 HP sled isn't really that impressive! Junior makes an excellent point also about actual HP at elevation. Must be sick riding these thing in places like AK where you are near sea level in places!Ok.....So you are getting 10 psi on Stock Injectors. The stock injectors are a 630cc injector at 43.5 psi. The ProRMK is running 58 psi so that makes those 630s flow 727.46cc. A fuel injector that is flowing 727.46cc can only fuel up to 180 hp at 80% duty cycle. You can run those injectors at 100% duty cycle but the on/off time of that injector will only allow you to get up to 85% duty cycle on that exact injector. Now I imagine you are jacking up the fuel pressure on the stock pump.....which usually lessens your fuel volume from the pump, but i haven't seen a chart for this pump yet. So if there is a rising rate regulator in the system...we'll say a 2:1. So now at 10 psi we will have at most 78 psi of fuel, which in a perfect world will allow you to run 214 hp. So turbo kit at 10 psi is only increasing the horsepower of the sled 214 - 150 = 64 hp gain at 10 psi, which is 42.666667% more horsepower...not really that efficient.
If you don't agree with my math i'm using a calculator off the following website:
http://www.gtsparkplugs.com/InjectorSizeCalc.html
Ink....
I am glad to see that your post that you left last night at 11:09 was pulled off...
You have lost all rep with me as far as I am concerned. Low blow..
Why would you say something like that???
Sometime the truth hurts, but the reality of this situation is that I am not on here to make friends. I am frustrated with the lies!!! and will continue to call out the people on here that are just in it to sell kits and will fix the problems after you guys complain. That is not what you do!! DON'T RELEASE A KIT UNTIL YOU HAVE WORKED OUT THE PROBLEMS YOURSELF. DON'T LET YOUR CUSTOMERS DO YOUR R AND D.
