yeah. i never got around to changing the fuel filter this season. Ill have to order one.Check fuel pressure and replace filter if you have not already this year.
You can remove VES covers and check bellows for leaks and at that time valves should move freely if they do not pull them and start cleaning, let us know how it goes!!
Thanks guido! I know i should have replaced it. Just never got around to it. If thats my problem im going to be pissed. lolyou should replace the fuel filter EVERY season.
get this one, WAY cheaper then polaris and a direct replacement, ive used these for 3 yrs...
http://cgi.ebay.com/ebaymotors/ws/e...0720447766&viewitem=&sspagename=STRK:MEWAX:IT
Would that cause a high idle and the symptoms i described?Dead spot in TPS maybe?
well it bogs at any throttle above 3/4....Youre saying if it was a dead spot that it would be JUST at 3/4?probably not. just at one certain spot in the throttle (3/4).if you have a TPS tool and an analog meter its a simple check maybe your TPS is going bad who knows . as for the new symtoms you should go over your work if something new has started.
Installed it at the beginning of the season. Was running fine after that. Ive got 5 rides on it since i installed it. This is a new problem.Noticed you have a FBF cable "set". Does that include the throttle cable and how long ago did you install it? Was it running fine after the cable was changed?
Checking the boots is on my list.. Theyre brand new however. Only have about 5 rides on them.I would set the TPS just because. Then pull the fuel rail and check the boots because an air leak might cause your symptoms.
All ive done so far is just replace the fuel filter. I dont see why that would cause a high idle. And the high idle isnt all the time. Like the first 2 times i started it up the idle went slowly up to 2100 or so. THen the 3rd time it idled fine(1600) for a few mins then went up to 2100.
No I've been working on it today... now its idling at 2600. Still bogging at high rpm and now its backfireing. And this is after I set the tps.SKS did you ever find the issue. I have the exact same problem with mine. Went through same steps you have and still no luck.
Yeah. Im kinda lost right now. Since i dont have access to another 900 i cant really switch out parts.My 900 idles fine 1550 rpm goes into reverse no problem and no back firing just bogs like crap above 3/4 throttle. Have done everything you have and still no luck. I will keep digging if I find anything I will drop you a line.
