Anymore suggestions? I need to get this sled going.
As long as you "gift" it back to me after you get it running.give sled to me as a present![]()
I think the shipping cost would be ridiculous though. hahaHey, I would actually be willing to do that. It will come with a bill for whatever parts it needs though.
Theres no way to test them right? How do i know which one? lolBad Coil, my brothers coil on his 900 was going out it would bog on the top and idle funny.
So could a bad coil cause the high idle? Its idling at about 2600rpm.....
It started being high well after the bogging started.. But it seemed to get worse after i adjusted the tps.. The tps is dead on... I suppose it could be the harness. But im not really sure.I can't see that happening. When did the idle start being so high?
High / unstable idle and backfiring screams air leak to me.
I remember a time when my throttle bodies had popped out of the intake boots (big air leak) and it was doing the same.... idling at 2500-3000, and backfiring
I honestly dont have as much experience doing this stuff as most of you all here on the forums. This season ive learned alot!Whats your methods you have used to check for air leaks so far?
I usually leak down test any of my 2smokers after a rebuild or assembly, it's in my opinion, the best way to really know your engine is sealed. Most leaks are found very quickly this way.
Of course this only covers the parts up to the plugs you use (a plug in the exhaust manifold, and a slug clamped in the intake boot is typical). This doesn't cover your boost box, the boost box's seal on to the throttle bodies, and the throttle bodies seal into the intake boots which also all need to be properly sealed.
Unless you set the tps incorrectly somehow, I still think this sounds like an air leak. but even if the tps was done wrong, and the throttle plates were open too far at idle... I would expect the problem to be consistent.
That said, with these 900's I have found that until you have a perfectly operating and set tps with good idle behavior... all sorts of other problems can plague you (your 3/4 throttle bog that was the original topic).
If it were mine, I would start by re-setting the tps making triple sure its right, and doing a leak down test... and go from there.
