I have the edge suspension....with 7041940-067 SPRING-TORS,.405SQ/77°,BLK,LH (Opt)(.405/77) 7041941-067 SPRING-TORS,.405SQ/77°,BLK,RH (Opt)(.405/77) love the ride with the springs....... but I'm gonna lose a wheel soon!! the rubbing happens in the bottom corner of the spring....just barely touches, but the heat melts the plastic! the wheel had 10mm from the bearing and now I have 2mm left and the bearing is about to pop out of the wheel. I ordered the whal bros billit wheels and they come with 20mm standard bearing @&^%^!*^ (6004; 20x42x12) I am ordering some Kart wheel bearings that are 20X42X9 and 3mm thrust washers. The whal bros wheels are a LOT thinner then stock polaris with the 15mm wide 6205 brgs....now if the 9mm bearing is strong enough this should fix the problem!! I will use a spacer to get the proper alignment and keep it from floating into the spring! If it works well I'll post the info for all!
