thanks for the inputs guys..i will go this route for sure..all depends on $$, no one has as much as Nolan.
Sean, What are the part #'s for the heavier springs? My sled sags a bit to much and I'm running 235 on a good day.
Thanks
Mark
I see the 375 I think are 7041942-067, 7041943-067.
Would the 375's be ok or would I need the 405's???
What can I say! I just know what I want out of life! If I put money here I have to sacrifice somewhere else thats all. I have 1 sled with some goodies. You have umpteen sleds/bikes/trucks! Wanna switch straight up? lol jm. Like I said before; you can't go upgrading everything to highhell because im getting tired of having to one up you. I worried im not going to be able to keep up with you on this trip we are going to take this winter.
Go with the big boy springs and enjoy!
HA!!
Nice...well, like i said, i have to have something to dump money in..shoot, lol..
i will out due you one day..well actually i will tomarrow, i have my sled 20 ft away from me..LOL!!!
we will work the trip details..EVERYONE needs to get in on this..i cant be the only one that wrecks their sled!
I am wondering with aftermarket suspensions is there still a torsion spring? If not what are the provisions for us big boned, 185 at heart, guys???
77 degree springs are for the IQ skids (non IQR)
the 90 degree springs are for earlier models. They have too much preload in the IQ skids.
i cant be the only one that wrecks their's or their wife's sled!
there are guys running the fatty springs i read in teh past and they were 200 w/o gear??
That's what I am. Just run on the softest block setting. I like it way better than the stockers, seems a lot more responsive. plus I can always switch the block to a stiffer setting down the road. had to run the stockers on the stiffest setting and still felt they were lagging and definately too much sag imo
You should also consider the 7042079/7042080 torsion set. They use a tighter spring leg angle which gives you a little more preload at the top of the skids travel.This helps a couple things...it allows you to run the spring on a softer setting and still supports you and the sled properly which extends the life of the spring. The spring will also have more effect at the beginning of travel which helps eliminate the dead spot all these skids have-this unsprung/undampened area of travel is a big reason why the IQ was a bit on the wild side with weight transfer-to much scissor collapse right off the bat.
These are our go to springs for any one over 220#(which I'm one of by the way!) I have a full season on them in my turbo 163 and they are still on the soft setting-haven't had to add any more pre load since installation which indicates that they are not "sacking out".
curt
fixed
curt
How about save the $$ and put in a few extra laps around the firehouse J/K! HAHA couldn't help myself !
So "my friend" is around 275lbs and he wants it stiffer in the back, he has a 07 rmk 600 155-should he run the biggest springs for his fat a$$ part# 7041942-067 & 7041943-067 or is there a better spring. And should he put the carls front track spring on the sled also.
He says thanks in advance
Curt Really knows his stuff on the Polaris skid setups... probably better than anyone out there that I know.
I'd follow his lead without hesitation on this.
Part numbers
7042079-067 Spring, Torsion, LH, STD [.375/47 °]
7042080-067 Spring, Torsion, RH, STD [.375/47 °]
