OEM Pistons
This is what Curt had to say:
"Hi Tory, since the 800 dragon first showed up in 2008 the cfi 800 has had the same issue and we have stuck with the same program to correct it. IMO you can't beat a Elko OEM piston, we correct the bore size if clearances are to loose (this has slowly gotten better from Polaris over the years) by re nicasiling the cylinders to our spec and stick with the oem piston. Excessive skirt clearance is the cause of the piston/cylinder skirt failures experienced over the years on the cfi 800.
Long story short, we tell our customers that no matter what they do, that cylinder won't safely run ANY piston beyond 2000 miles without risking skirt failure-any model, any year. We get them on a program to measure clearance at 1500-2000 miles and drop in a new set of pistons if needed. I can honestly say we have never had a skirt failure with that program.
Installing the "13 cylinder will add durability to your engine, check the clearances with new stock pistons and they need to be .0055-.006" max. Correct the bore if they exceed .006".
A real port job with a good pipe and head and that engine will make 170hp trouble free and typically need pistons replaced every other year assuming average mileage per year for a mountain sled.
Hope that helps!
Curt"
Hope that helps!
Curt"
