As as far as weight, maybe float shocks
Ti Can -18 lbs
LW Pipe -3 lbs
LW seat -2lbs
Carbon Tank -8lbs
Carbon body panels -8lbs
Ti A-Arms -2lbs
Ti / Carbon Rear skid -14lbs
Ti Bolt kit -2lbs
Delete the headlight -2lbs
Ti Running boards (Diamond-S) -3lbs
Drop the center driver -1.5lbs
And I know I'll catch heck for this... but Walker-Evans Air shocks...
They are the absolute lightest and, IMO, work for a mountain-only sled.
For me... with good valving, good shafts and good oil... they worked.
-8lbs
-71.5 lbs total
Puts the 155 PRO, with a stock weigh of 408 lbs dry, at about 336.5 lbs DRY ......WOW...
But you are probably looking at some serious cash!!
That would make it about 400 lbs even...RTR.
Go with a lightest decent mountain track... say the 2.25" power claw 153".... and you could drop another 4 lbs out of the sled.
Do the "Carl's Cut" on the skis... good for a half pound of plastic.
Take a .6lbs of rotating mass with the TJ carbon clutch cover.
If TJ does some spindles for the the AXYS mountain... figure -2 lbs.
So with those items... Hmm... a 329 lb sled may be possible... Crazy![]()
Is there a positive confirmation that the slp pipe setup WILL work with the axys rmk?
I'm Thinking to avoid the rush and order now to have it on the shelf come fall.
I would also like to know the width at the front of the running boards so i can begin building my boards for next year.
The Front + Rear Float Kit offered by Carl's and Polaris only saves 1.25lb and it's all in the rear, the fronts are actually heavier vs stock..
SLP has a pipe and pipe/can set for the 16 RMK already listed on their site. I bought the pipe/can set for the 15 Axys long track build I am currently working on...if we get some more snow, I will have it out this season...
The standard float 3 are just under 2 lbs lighter on the front, the evol chamber shocks don't save any weight. My float shocks on the rear suspension saved 3 pounds.
Are you guys comparing to the non-clickers? I got to think the evols are lighter than the piggybacks?
I saw a 15 Pro (900 Carl's) being built up for some dude in Nova Scotia or another part of Eastern Canada. It had a carbon fiber tank, side panels, hood as well as a whole bunch of other lightweight pieces and parts. I don't know what the final weight ended up at but I estimate that he was into the sled for $45 large. It was nice but way out of my price range. I figure that an investment of $1,000 could yield about a 20 lb. decrease. After getting at the easiest things like the can and a few others mentioned by MH, the price per lb. is going to climb very fast. As he so graphically showed us, you could get a sled that weighs 400 lbs. or so ROR but you better have a big wallet. I will be satisfied with the 20 lbs. that I can reasonably achieve within my limited budget. It will still be a very lightweight sled and you will have money left over for a nice lightweight mountain bike to ride when there is no snow. My mountain bike season has started a lot earlier this year in Idaho due to lack of snow. It is fun but it is not the same as riding a sled all day in the mountains. Get a 16, make it lighter yet and hope for a decent snow year for the winter of 15/16.
