Hey guys, I have had a lot of "pod" and intake questions this week. I thought I would go a little deeper on the importance of understanding the intake boot and it's effects. The manufacturer's have precisely tuned the length, diameter, taper, rate of taper of the intake boot for the specific engines performance. When you are experimenting with intake and "pod" ideas, it is very important to closely replicate the "velocity stack", "ventury" design the manufacturer has determined and "built in the intake boot" for your specific engine.
Any form of intake will allow your engine to run, but with large deficits to performance. Take some close measurements of the stock boot. Small diameter length, taper "up" length and rate. Then design your system around those measurements.
I will attach some explinations from the old French physicist, Bernulli...;
Modern engines universally have tuned intake tract volumes and associated resonance frequencies, designed to provide higher than atmospheric intake air pressure while the intake valves are open - increasing the density of the trapped air in the combustion chamber (higher compression). Modified engines often have the original air box and associated ducting removed and velocity stacks are installed as accessories.
Modern fuel injection systems with a plenum and single air inlet typically incorporate some sort of radiused entrance, designed to improve power, based on air flow increases. Power gains are usually at higher rpm.
The length of the stack is known to have a direct effect on a particular engine's boosted power range.
Image; *** enlarge the second image*** very good visual representation
