Are you running just the hand brake or a dual? Took mine out today for the break in and the hand brake was very spongy feeling and didn't feel like there was much braking.
Are you running the 12 tooth engine spoket or did you change to the 13 ??
13/17, 16/17
my friend just pulled the trigger on a 2014 lt and a 2013 new never run sx-f. He's a big guy I was hoping to stick with stock kit gearing so he doesn't have to keep buying more and more stuff. looks like you geared up? will stock 13-17and 17-20 work or is the 13-17 and 16-17 where its at? Also after reading through here again is the boondocker pod a no go?, I have the parts to make him one on hand, but it sounds like u are liking the modded airbox. we are in Bozeman mt the powder around here is notoriously pesky! Any updates on the build? Thanks for all u have done documenting to help others out!
Belleville spring up-grade. Hey guys, I imagine everyone knows the 13.5 and Dungy models to current run the 280 spring. The 2013 model runs a 250 spring. The 280 simply applies more pressure to your clutch stack. Quicker lock-up's and more holding power. Here is a quick install. Remove your clutch cover, remove the 6 hub bolts, remove the hub and Belleville spring washer. When installing the 280, be sure and index it properly to the stiffest setting. To do this, find the marks, I, II, III or X, Y, Z on the center hub next to the bolt holes. Install one 6mil bolt in the hole marked III or Z then find any one of the six bolt holes and turn in in a few turns with your finger. Then take your remaining 5 bolts and install. Starting with your first in the III or Z hole will properly index you to the stiffer setting. Be sure to not over torque. Over torquing will cause clutch drag. Torque to 55 in/lbs or 4.8 ft/lbs.
