M
mtn-doo
You wire in a simple 4 wire + signal wire relay. They are available at NAPA. The hot comes from the battery, through the relay, then to the grips. The relay is simply "in line". All power to the grips is being pulled from the battery while the bike is running and the battery is constantly being fed by the coil. No "net loss". The relay will not close, "connect" and send power without power being applied to the signal wire. An independent hot source. A relay needs power to "close" the circuit. That power is not coming from the batteries or the relay would always stay closed. You want a signal source that has available power ONLY when the bike is running. That way the relay "opens" when the motor dies, and closes when the motor is running. That signal source can be ANY source that is "hot only" when the bike is running. A relay needs a separate power source to open and close. No signal power OPENS the relay. Power or "hot" signal wire closes the relay. The amount of power needed for this signal is minute. No battery or grip amperage ever see's or uses the signal side of the relay. The fuel pump hot is a good source. It is only alive when the bike is started. Once the bike is running, the amperage flows through the relay to the grips. The Hi, Low, and off features all work normal. You can have the bike running and turn "off" and "on" your grip heaters etc. The important thing is when your heaters are "on" and you shut your bike off, the engine stops, the "signal power" goes away, that opens the relay and power stops flowing to the grips. Regardless of switch position.
I asked the crew at Penco Power Products in Kalispell, Mt. if they would be interested in making a pkg for this with instructions for retail sale? I don't sell from my shop. I will keep you posted.... In the meantime, get some water tight connectors, wire, and a 4 wire relay, and you're good to go!
