OK - more thoughts of mine for you all to read (assuming people are actually reading this!)... Sorry its soooo long:
-the Ti springs look to be an issue. I heard this from a few top sled builders out there (i won't drop names, but you've all heard of them
). So to check their comments, i pulled the primary spring out this morning before work and sure enough its much wider in overall diameter than the steel springs are... So this gets me thinking that i may very well be dealing with a coil bind issue... the Ti spring actually got STUCK in the primary cover!
- to further that thought, i'm beginning to believe that i may NOT have an alignment issue. I'm starting to think i've just got a slipping belt (in the primary) issue. My black pen method has worked perfect of years and currently i'm showing PERFECT alignment... hmmm.
-so i'm going to go after a fix in two ways, unfortunately at the same time (unless someone wants to donate a steel ylw/wht to me within the next day!). First, i've confirmed a number of times that torsion springs seems shift out faster on the bottom, get stiffer more expontially than compression springs. Their benefits are in their smoothness of operation - no binding as they shift like compression spring does (thus the popularity of the shift-assist devices). All this to say, that i like the "idea" of a torsion kit and will continue to play with it for now. i've got all the parts on the bench ready to go back to compression if i want to though. So long story short - the 1000 makes the torque to pull a softer spring than the ylw/white off the bottom and i'm only starting the helix out at 38* so a harder shift out from the beginning shouldn't cause any further issues, and i like this feel personally. BUT - i need a spring that squeezes a little harder at climbing speeds of around 52mph where i'm streaking my primary. In addition, i believe my Ti spring being so FAT was causing it to act EVEN stiffer in the primary and causing coil binding, perhaps not even a straight out pressure increase, which could've caused my only half-circle black streak. So, i'm gonna try a slightly less stiff spring in the ylw/grn.
-All this to say - i think Ti springs are causing problems and i think with my specific setup i need a little softer finishing primary spring or more tip weight. the spring is easier, so i'm gonna try it first. Yellow/Green 114-267 vs. Yellow/White 122-285. Kelsey likes the orange/white Orange/White 143-290, but i find higher starting/higher engagement springs always build more primary heat. plus i ride trees often and enjoy the ability to get quick pulls off the bottom-end. I really liked the gold in my m7 w/ twins and its 75/275...
-one last thought - if you are really following my belt issues and my list of mods, you'll note that i did do some alignment mods, though i kept having belt heat. I added a torsion kit as well, which seemed to help just a littl bit, but my belts kept burning, THEN i geared down and things got better, but didn't get fixed all the way. Hmmm - the gear down changes my alignment again because its puts clutches FURTHER into the shift at the same (or close) given track speed. Well, now i'm back to trust myself again - my alignments good, i've just got a balancing issue between the clutches... more primary squeeze at climbing speeds and i hope i've got it fixed!
Comments please
