AXYS Backcountry Tools
lien2747
New member
15
1
3
38
Fargo, ND
Hey everyone. I’m interested in what everyone brings on rides for tools for their Axys. I’m thinking of putting a little kit together. I have seen the burandt tool kits but I’m not too worried about a few pounds and feel like you can make a kit a lot cheaper. Any input would be great.
Thanks!
Sage Crusher
3,272
1,198
Rock Springs,Wyoming
I share the load with my riding buddies- They carry the fuel and I carry the tools... One thing for sure you cannot have to many tools out in the backcountry ..even a ratchet strap has got us home with a broken suspension, and hose clamps for a broken tie rod.
Using your imagination will award with a unique load of tools.
Yaeger34
327
155
St cloud mn
I feel it is a little more challenging now days since things are torx, philips, etc
torx allen set or just a couple little ones that fit the few bolts
screw drivers,
vise grips,
needle nose,
little spring puller
few common size wrenches
wratchest straps, 2 preffered
duct tape
hose clamps
nothing too crazy. That goes in tunnel bag as long as the bulk of my food/water. I eat out of the tunnel bag always. Save my 2 waters and protein bars for my pack. Often keep a reeses fast break and a mountain dew in there for a little sliver of happiness if I ever end up in a overnight bad situation.
Wheel House Motorsports
29,933
5,970
SW MT
The axys is pretty damn standerdized.
10 13 15 and 17mm sockets, small extension, same with a t40(or 45?) Good adjustable wrench(x2) and vice grips.
I have done full tunnel swaps on an axys and I can assure you it doesn't take many tools to fully tear this sled to a pile of parts. Just make sure you have a handful of the right ones.
Scott
Scott Stiegler
69,618
11,737
W Mont
That's the post of the year.
snowracer21
308
208
On top of what everyone else mentioned, I recommend carrying a spare belt deflection adjustment screw/nut for the secondary clutch. Mine broke just as I entered into a riding zone with shoulder deep pow. Made for a very interesting trip back to the truck.
Sheetmetalfab
7,938
6,699
Hasn’t everybody done a few full swaps?
GreenState
427
233
McCall
A little tool that got added to my tool kit last year (it actually lives in the front pocket of my vest) and proved to be really handy was this little Topeak Ratchet kit. The ratchet is nice, not chintzy.
For our application:
-Swap the tire levers out for a 3/8" socket adapter for an impact driver
-Remove the T10, 2, 2.5, and 3mm bits (those don't exist on our sleds)
-Add a 1/8" driver tip for adjusting belt deflection
-Add T30 and T40 bits
That will pretty much take care of all the small fasteners on the sled.
The other tool that lives in the front of my vest is my Leatherman Crunch.
Q
Mar 11, 2011
146
91
Olds
Wrenches - Metric 8, 10, 13, 15,
Wrenches Standard – 7/16”, 9/16”
1/4” drive Ratchet
1/4" drive extension
1/4" to 3/8” adapter
Allen Wrench Set – Folding Metric
Torx set- Folding
6 in 1 Screw Driver
6” Crescent Wrench
“L” Allen Wrench 6mm
“L” Allen Wrench 4mm
Needle Nose Pliers
Sockets
15mm 3/8" drive Deep
13mm 3/8" drive Shallow
17mm 3/8" drive Shallow
7/16” ¼” drive Deep
8mm ¼” drive Shallow
10mm ¼” drive Shallow
Build these kits anywhere for pretty cheap, just don't buy junk, when you really need something and it breaks because its garbage, On a snowmobile in the middle of nowhere is not where you want to be
Sheetmetalfab
7,938
6,699
1/4” drive Ratchet
Torx set- Folding
6 in 1 Screw Driver
6” Crescent Wrench
Needle Nose Pliers
Sockets
7/16” ¼” drive Deep
I run Very similar.
(Plus spare parts a 5/8 or 16mm for rear axle bolt and a 1/8” allen wrench for belt deflection)
Long handle 1/4” drive snap on ratchet FTW.
Dec 4, 2007
114
41
1/4” drive Ratchet
Torx set- Folding
6 in 1 Screw Driver
6” Crescent Wrench
Needle Nose Pliers
Sockets
7/16” ¼” drive Deep
What fasteners have you found that are 7/16" and 9/16"?
Sheetmetalfab
7,938
6,699
7-16” is belt deflection jam nut.
9/16 will work for a 14mm bolt but often not the other way around so i carry a 9/16”.
Note the added 1/8” allen for belt deflection and 5/8” / 16mm wrench for track tension adjustment.
AndrettiDog
6,329
2,478
Colorado
These are all good ideas. But add a couple good small rags. Nothing worse than having oil all over the place and nobody wants to use their Klim gear to clean it up. I had a chain case fail and that was a mess.
willjogervais
438
254
SW Minnesota
Nobody has mentioned paracord, I bet once a year the paracord gets brought out for somebody's sled.
The uses for that stuff are limitless. Cut a branch and lash that sucker to a broken a arm, tie rod, or shock. I've even rode for multiple days in cooke like that with a bent/cracked alternative impact a arm on my axys. Wrapped a 1-1.5" stick from one end to the other. Broke the stick once on a jump i shouldn't have done, got a new one and kept on going till I got home and got a replacement a arm. It doesn't take up much room in my tunnel bag and I never go anywhere without it.
