Hawkster..
This photo shows clearly that your track is ratcheting.... The driver has slipped, riding up on top of the involute nubs.... and the center driver teeth are riding up on the rubber between the windows.... that is what ratcheting is.
Is the muffler side (mag side) driver also riding up on top of the involute nubs at the same time?
You could go to your dealership and do the straight line check with a ruler while it is still there.
If you have not tightened your track since buying it... It is probably loose... SOME dealers I have run into, believe it or not, don't know proper tension either and believe that the center extrovert allows the track to be run looser and with free hang (no weight and a visible gap between the track and rail when the sled is suspended in the rear with the track off the ground)
when this happens the track is tight
Yes... WHEN this happens (the track is ratcheting and the drivers are riding up on the track.... having the same effect as tightening the track by more than 1" on the rear slider.
I suggest going to the dealer, with your owners manual in in one hand opened to the page that outlines proper track tightening....a 10 lb. dumbell in the other hand (consider it a tool for future use as well... get it at K-mart or a sporting goods store for around $10)... and a 12" ruler in your back pocket.
Do the check first that the sprockets are in the same line as shown above.
Next: Loosen the track at the rear to allow you to fully seat the drivers in the windows/involute nubs... then place the weight on the inside of the track, between the rails and adjust the track tension to the proper 3/8" sag (making sure that the drivers remain seated in the nubs/windows as you tighten)... the end result should be 3/8" of space showing between the track and the rail with the rear axle in the same position within the adjustment slot... measure the axle position carefully and re adujust so that the 3/8 is maintained
AND the adjustment is equal on both sides.
This adjustment/check is part of owner maintenance and should be done every ride for the first 3 rides and checked regularly through out the season there after.
It is VERY VERY unlikely that the drivers are different diameters... the "line check" outlined above as well as using the ruler, laid
Between the teeth of the drivers that has all three drivers, except for the extrovert tooth, in the same line... with the center able to sit slightly lower than the two outside drivers. Do this between EVERY tooth to make sure that the drivers are not "out of round" on the axle (which is also Highly unlikely).
If, after tightening the track as outlined above, this still happens, or you find tight spots where the track is more difficult to pull around.... I believe that your driveshaft is bent ...
This can happen from time to time... from impact or ice chunks or from locking up due to tension issues... the only way to check for a bent shaft, accurately, is to place the driveshaft between centers on a lathe and check for runout... not possible to check this
accurately with the shaft in the
sled with the track in place.
