I'm interested as well as to what your "Gremlin" is?
They did not discontinue the track .... they discontinued the 146 track length... The track itself is still alive and well in the 155 Assault.... same track, just longer.
The reason?.. Polaris needed to be competitive with the other mid 150" length Hill Climb sleds out there and for
Homologation rules... it need to be offered as a consumer available product.
The 144" Assault is not an RMK... But a Switchback with shorter lug track and a different suspension. The RMK has a coil spring (coilover-shock) completely re-designed, mountain specific suspension. The Switcback still features the torsion spring suspension from previous years just beefed up a bit.
The only issue I know of with the Assault track is when owners operate the sled in speeds in excess of what Polaris specifies on the large handlebar tag that is on the sled when you buy it. I believe it says do not exceed 70 mph with this track. Some people that have had paddles de-laminate from the track belting.. this happens when, INTERNALLY, the lug root overheats (and not from lack of scratchers or too high of coolant temp). When the lug root overheats, the rubber physically changes and de-laminates from the track belting. Now, the lug may not come loose for a while after the damage happens but the damage has been done and lug problems caused by operating outside of the tracks intended design limits can pop up later.
This is, 99% of the time, caused by ignoring the warning provided by Polaris on their tall-lug tracks.
If your sled did not have this tag on the bars when you bought it, the dealer took it off; which they are not supposed to do... But the info is also in your owners manual.
All tall lug, tracks, especially stiff ones like the the Polaris Comp track and the CE extreme, cannot be run at high speed on hardpack backcountry situations or trails and be expected to last.
