I remember it was mentioned that perhaps in June they would start being the kit available/order-able. Anyone know if there is any new news on the kit?
From what I understand the vertical steering kit won't be available until early winter (like December). I heard that from an engine designer guy at the Arctic Cat 50th thing. He mentioned they had a problem with the bearing on the assembly and had to do a redesign.
Ill have a M1100T SP Friday and get ya updated
I heard the same thing from Ken (from push turbo) at grantsburg watercross. He said they had something wrong with a bearinng in the setup.
On another thought. . . Any chance that the hold up on the turbo sleds is the steering post? That they are trying to get it developed and tested to go on some production sleds. I would be will to pay a couple hundred extra for my sled if It came with the adjustable post. Because I am sure the riser stock on the standard m1100turbo is not going to tall enough so I will be spending at least $30 on the right height riser.
I have
Is there any problem with the Vert Steering post on the 800? Does it have the same bearing issue?
Sled won't be here till Monday but you guys are correct no part numbers as of yet but i think it will be before early December more like late September as per the head of Cat Parts and Acc.
