running clicker 4, and hope to be lower when boost is turned up, yes that day we came in from bolder, the day before we came in from eagles pass parking lot
23 grams in crazy. Take some out and put in a higher finish rate primary spring. "
if i put in a higher finish rate it would rev more after removing pin weight... you mean a solfter finish rate after removing pin weight...
for now its good, once we are at another five more lbs boost, it could need a complete change
What clicker are you on with the 23 grams? Did you come into Turtle from the Eagle's side or Revy side. I could see the fingers off the lake at Turtle in your vids.
