How many miles on this sled?
Can you pinpoint when at what point Det is triggered?
What exactly happened to the crank? Failure? Rod bearing by chance? I’d like to know more about the motor failure. Was the motor failure from detonation or the result of something else?
Have you replaced your motor mounts? If not, I’d do this first.
Solving Det in a Polaris can be tricky. There can be instances of false set Det from poor clutching, worn motor mounts, something rubbing, something loose and vibrating. Pipe rubbing the lower overstructure has been the most common.
