You asking if "dj clutching causing it to lag". Umm, clutch settings cause improper boost control?
Im going to say your friend who says "i'll get back to you", he knows nothing about the engine management. You would be better-off asking a cashier at home depot. Not knocking him, just he does not know anything about
your circumstances, get it!
Question; is it "the clutching fault" If the blow off valve or boost controller management or cats and dogs start living together? "its the clutching fault?
No...if the engine power shape is not managed correctly, engine torque rise moving around; doesn't bog from 5 to 8k feet, starts to bog after 8 to 10k+ - then its like trying to shoot a dart at a swinging dart board and now try to clutch that?
Then you have mister ibexx over there saying bikeman engine management problem, ibexx solution. But only ibexx clutching works on ibexx tunes. So that means, dump bikeman and install ibexx tunes and ibexx clutching. But wait a moment...
Mister Ibexx says)
-Bikeman tunes run great. But that dip in the dyno is legit and does happen [problem]
-Ibexx knows what the problem is and has fixed it. [cause and solution]
-It sounds like the guys at maptuner may have figured it out as well [credibility name dropping]
[I love it,
![Love :love: :love:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i [me joey] did not have to say anything, use
their words]
According to mister Ibexx reasoning then maptuner should sell ibexx clutching because maptuner does not sell clutching.
IF you have maptuner then you also need ibexx clutching because ibexx and maptuner have "figured it out" but only ibexx clutching is working because of proprietary this or that....
Ok, then Evolution Powersports is about to come out with their own clutching too and they'll say "weve solved the problem ibexx has but you need Evo Clutching" Then the ibexx tune and clutching can be thrown out and go full Evo.
What could have happened is...
Mr Juggs emails ibackshift - "i have this or that problem"
Then I ask a bunch of questions....
and then say this...
your primary clutch spring is a 100/250
Raise the engagement speed a bit...
150/250 blue/yellow BRP#417224015.
The engagement will go from 2900 to 3400 rpms.
There will be enough spring force off the bottom end to allow "higher engine speed at part throttle".
When you press throttle, the engine will have about 6hp more to speed up through a boost control problem.
Do nothing but change the primary spring and go drive your sled. If there is a residual problem still, then contact me again.
It will be quicker for you to get one from your local dealer in USA [2-3 days] than me send one from Canada[9-11 days]
The internet....gotta love reading it between eatin these chicken wings.
