Good post. Remember it was stated that "one could make the case" not that is was the case. Just throwing out some information to chew on.
These peak and valleys, we all agree are required and present in the plating. That is not up for debate.
Here is what I struggle with: The statement, by Dan, that the piston will not last 500 miles before it is shot due to the cylinder wearing the piston down. The cylinder is not wearing the piston because it does not come in direct contact with it. If it does, you have failure.
These microscopic peaks and valleys are not "grinding" on the piston. It is like pressing a straw on an 8ft tree trunk. The trunk does not care because the straw is not exerting enough pressure to have any negative effect.
The oil barrier must be present in order for the piston to survive crank rotation in the cylinder.
If the oil barrier gets compromised, the piston will seize very quickly. This is an important concept and is key to the argument.
Oil is present with all cylinder finishes. If it is not, then you are done.
Whether one hone finish retains more oil than another is the question and one that can not be proven via any visual inspection of a coating that is designed to allow for less friction during break in.
One could make the case that the piston with the most worn coating is the one that has been more successful at flattening the peaks. Not saying this is the case, but it is probable.
So, the idea that these microscopic plating peaks are destroying pistons within 500 miles or even 1000 miles is not a theory I can get on board with and is what is being presented as fact.
The piston ring is the main component to see wear and it is not aluminum. It is subjected to the most heat and the most friction of any part of the piston. It also has a very small surface area contact face.
The piston intake skirt ,where all this attention is being directed, is not near as critical to the life of the piston.
Again, the ring is the main component in play.
It is the only piece doing any "flattening" of any peaks and is the main piece actually wearing under normal operation. Inspection of the skirt only shows the thrust points on the piston.
