Has anyone heard back from their dealers or polaris? I am out of words why mine is bogging, 2 other guys I know with pro rmk 850 that rides nearby here do not have this issue...
Just confirmed with our dealer they come stock with 68's but they went through the clutches and set them up with 72s. Pays to have a good dealer.
If a dealer is setting up a 160hp sled with 72 gram weights, it’s time to look for a new dealer. Or, at the very least, do your own clutching. She gonna be a dog.
Rpm should be more. You and dealer should attend clutching school together.
Any 850 clutched by a competent clutcheroo dood will smoke your sled. Post a vid of this rocket in action and let see if it’s a dog or not. Everyone’s sled is fast until another sled shows up. Cheers Mr. 72!
Really dude why do you have to act like such an idiot all the time on here? You just think you're the only one who knows better than anyone else. You really have no clue who you're talking to or what I or my dealer knows about clutching. Just for those stupid comments of yours you're not getting one cent of info from me.
The bogging issue is definitely a problem. Every one of the 850's in my crew has the same problem. All out of break in with 20ish hours. WOT is not bad but descents and slow speed technical maneuvering through the trees is brutal. It loads right up bad in all temps and elevation. Once you grab throttle you can blow out a bunch of buildup but it progressively get worse and the inevitable plug change will be next. It's a mapping issue with fuel and oil delivery IMO.
I have been in contact with Polaris and they are aware of the issue. They are currently investigating the situation.
And if you load it up too much by feathering the throttle near idle and then stab the throttle it can fall on its face because I believe it has filled the crank with excess fuel and then it chucks it at the spark plug all at once. I wonder if the new reeds could be playing a part here too??
Why do you think it fills the crankcase with fuel? How can it get there? I have had a small bog but it's because of to light of weight at lower elevations. I had a single ring rev load the crankcase with fuel also when the rings were wore out but there wasn't a sled that could beat it in a drag race if you let it load up.
Because it's the only way I can explain what is happening, other than I had a sled once that had a bad reed and it acted similar but I don't expect the reeds to be damaged.
Well....my Bog looks like it was related to clutch weighting.
All riding in 2-3 feet of POW at 1000 - 2500 feet, 91 Premium setting
Stock: 68g ramps. Over revving to 8600 and bogging regularly
Test 1: 74g grams: Wouldn't pull rev's, bogged a couple of times
Test 2: 72g grams: Pull rev's and peaking to 83-8400, no bogging and definitely in the wheelhouse
Test 3: 73g grams: Will know in a few days but fingers crossed.
For our sea level situation 72 is much faster revving and 74 seems to struggle to rev to 8150 so it's more a question of how "playful" you want your engine response to be.....if that makes
OTM
For our sea level situation 72 is much faster revving and 74 seems to struggle to rev to 8150 so it's more a question of how "playful" you want your engine response to be.....if that makes sense.
OTM
With the heavy weights, the primary clutch is yanking the secondary open and holding it open. The primary is being “the boss.” This causes lame backshifting, clutch heat and track spin. There needs be a “balance” between the primary and secondary. Clutch away and experiment!So I agree that that the clutching is off with the 850's or at least not as nice as the 800's from previous axys's. However, we have separate issues. I am also running 74g at 0-3k ft and will drop down to 72g. The backshift is almost non existent. Anyway, back to the bogging....clutching is not going to foul plugs, load up the engine, and blow out streaks of gas/oil into the snow when you squeeze the throttle. The mapping is off for sure.
Lots of good points here in the bog. I agree if motor revs to fast it goes to protection mode. Had this problem on turbo. Curious if this bog was there in breakin mode for the ones it's happening to?
Mine is doing he same thing be sure to let me know what you find out. It’s almost getting worse more miles I put on
