Jeezus, Tom, those are some pistons. I would keep them all and put them away in a box, along with your unusable cylinders. They would make a good going away present for the Polaris 550 motor director who works at Polaris.
For the prior guy who wanted to know, the Polaris part number for the 550 engine Oil Pump Return (bleed/vent) Kit is: 2203889
By the way, if you order a cool air ducting kit, it comes with one of the above. It comes with a molded plastic housing that bolts over the recoil housing (its a pita to put on, mine did not line up with the holes and I had to take a file to it), new mounting bolts, the oil pump kit, a heat shield for the y-pipe, and a new fuel pump bracket to mount to cooling duct. It also comes with 4 louvered vents, one for each side of the belly pan to evacuate hot air, one to place in the nose just under the bumper to direct cool air into the engine compartment, and 1 to mount on the cowl below the headlamp. This one lines up with the motors cooling duct intake. There is also a screen to go over the front louver, inside the pan, rivets, etc. There are instructions, but my kit did not include the template to cut the holes in either the pan or the hood. I had to copy a sled on my dealers floor. Polaris is basically trying to get the engine outside air for cooling, as well as evacuate hot air generated by the exhaust system from the engine compartment.
