4 stroke turbo
can i run 87 octane in my boosted apex if i shove a 1/4 inch shim in it to lower the compression to say 4:1 and still have good throttle response? I want to run farm gas in it, maybe even mixed with some water to get some water injection with my boost, I think it will mix better if I run the water with my gas at 190psi of fuel pressure. I also want to advance my timing to compensate for the slower burn of the water.....oh and I hope to run at least 22-25psi of boost from my gt12
what do you all think, I have been thinking of this for a few minutes now and think it is totally possible.
Why go to all that trouble and then run only 25# of boost? Your not a sissy are you?
Oh He11 just forget the gas and mix water with straight alchohol and inject at higher pressure you should hit 30 psi but keep the 4-1 comp ratio thats good thinking:eek:
