2nd bent matryx tunnel.
Thats not good... i thought you could rivet a new piece on like the ca
I broke 2 bulkheads on 17 the chassis was weak that's why they added a brace. That would have saved mine. Dont get me started on that pos
Same here! I did it twice in one season on my Doo.. One time was a small rock the size of my fist iced in the lake and was sticking out about a 1/8 inch and the second was from hitting a small stump under the snow.. Oh and blew the motor and at 1300 miles. Hence me riding Polaris now.
Thats not good... i thought you could rivet a new piece on like the cats?
Just the tapered tail (the last 6" or so supporting the tail light) is a separate piece. The main tunnel is all one stamped piece up to the bulkhead.
If anyone is gonna bend them on a wheelie re-entry, it will be the Khaos Boost guys on the 155. Early season snow certainly won't help, but hard or limited snow isn't exclusive to Nov/Dec. Did anyone hear of even one rhubarbed tunnel on the protos when they were getting trashed by the ambassadors?
Yup, pretty easy to get somebody with a metal break or go to a Machine shop to bend up a new piece and rivet on. Could go 1 step further and make it out of slightly thicker aluminum, make it longer and slightly skinnier to fit inside the tunnel. Did that years ago on my old mod indy when i removed the heat exchangers from the running boards and put a heat exchanger in the tunnel. worked slick, never bent a tunnel after that.
Im thinking of fabing 2 c braces to mount on top off the tunnel and fasten it down to the accessory factory holes.
I saw this on insta today on @aksledjunkie story so something to worry about this year....
Sent from my SM-G965U using Tapatalk
question? if the coolers went all the way to the back of the tunnel would this still happen as much? I would think the coolers gave some extra re enforcement ?
Kiliki,
Just did some research, it seems this “instant buddy seat” is a new option to accommodate stranded riders in case the motor recall update is a failure. Also an option for those whose snow check is still in processing to see some hill time this season.
My dealer received a letter on it.
Be careful when you get stuck. The right guy helping you, could fold your tunnel like a taco!!o_O
Looks similar to the production model ascender tunnels.
The early build ones had thicker tunnels and no issues.
One wheelie over on a brand new 18 snowcheck mountain cat and she was done.
Keep those aftermarket guys in business
