Rode Brandywine area today. Long pulls hit 8000 and pulled down to 78-7900 and held it. No popping and no boost loss since 38mm pivot bolts were installed.
We need pics.Rode Brandywine area today. Long pulls hit 8000 and pulled down to 78-7900 and held it. No popping and no boost loss since 38mm pivot bolts were installed.
I have not. Will check it out.Have you heard anything about the Turbo Tamers?
Turbo Tamers Clutch Kits
Riderz Turbo Tamer Clutch Kits BACK IN STOCK!!! FINALLY! A Riderz turbo clutch kit that has been built with extensive testing on Gen 5 and Gen 4 turbo's. Paired with our well known Turbo Tamers, the kit includes an upgraded secondary spring and helix. Also some P-drive weights/ramps that make...riderz-shop.ca
I also rode brandywine yesterday. Wow one of the best days of the season. I have 23 Lynx turbo R and have been fighting excessive rpm since new. Like an old girlfriend, always wanting another gram. I had a stupid amount of pivot bolt weight, Joey clutching, cleaned and inspected numerous times. Could not find balance between snappyness and not over revving. Until yesterday. Installed High Torque rollers in secondary. RPM went from 8000, 8100 right down to 7600. Took a couple grams away and wow. Finally. Snappy throttle response and 7900 rock solid. Pulls like a mother. Friken arms are sore today.
My 23 had has the exhaust spring curse dealer found a spring inside the pull starter something that had to have gotten there upon factory assembly. I think I’m going to weld the bracket back on does anyone know the material of it? One of my strong magnets barely sticks to it almost like the weld slag is the only thing magnetic on it.^^^^i would think it is warranty^^^^
They have a bad angle on those springs, with a sharp edge. Seems to break some springs.
My 21 lost one, installed 4 new ones. Keep the other three as spares.
My 22 didn’t break any.
My 23 broke one the other day, dealer gave me a new spring. Changed the other three for new ones, kept the old ones as spares again.
Also get out a magnet and find as many missing springs as possible. Hate to have one bounce though the clutch system.
For comparison, I've got the same 38mm pins on clicker 3. At 8-9000ft, I see ~8100-8300 on throttle stab and it settles in around 8000-8200 depending on the snow. I still get the backfire and loss of boost from time to time. Next year's machine will get a different clutch setup to keep it from screwing me over on a do or die pull.... disappointed in the factory clutching for sure.So I've got about 1100 kms, 400 kms with the 38mm pins. Clicker 4, spring snow, pulls 8000 rpms, drops to 78 or 7900 on long pulls. Can feel the loss of peppiness on the bottom end. Sled tends to jump off the start. Will def need a clutch kit to keep from over revving, popping and losing boost and maintain power throughout the band. SHR or DJ is the question. Lots of feedback about SHR, haven't seen much regarding DJ.
Exactly!!!i am positive that the stock clutching has been disappointing since my first Ski-doo Mountain sled in 2001, i can not remember of a single 1 that i did not have to rework both clutches, then along comes Joey at Iback shift and now every new sled gets his magic kit installed before the sled sees the snow outside of the shop
have you checked your boost tube? (i think thats what its called). mine was snapped off. i have no idea how long. but i was getting the occasional backfire. and when its snapped off you are blowing exhaust through the hole into the open under your hood. i suspect there are many sleds out there with the boost tube snapped off and owners have not pulled the hood to check.So I've got about 1100 kms, 400 kms with the 38mm pins. Clicker 4, spring snow, pulls 8000 rpms, drops to 78 or 7900 on long pulls. Can feel the loss of peppiness on the bottom end. Sled tends to jump off the start. Will def need a clutch kit to keep from over revving, popping and losing boost and maintain power throughout the band. SHR or DJ is the question. Lots of feedback about SHR, haven't seen much regarding DJ.
