Thanks, I think I might try this since I think the powerclaw 3 inch is superior over the polaris 3 inch.Yes, direct swap, they are both 162's.
Sent it
Sent it
Except for sidehilling, the powerclaw will washout before the Polaris track will.Thanks, I think I might try this since I think the powerclaw 3 inch is superior over the polaris 3 inch.
Awesome, ya I think Ill try running it stock for a bit anyways. after running a doo 850 and the cat 800 I find the powerclaw just to be the most durable and works so darn good. This will be my first polaris so time will tell.Except for sidehilling, the powerclaw will washout before the Polaris track will.
For my Khaos, I had the same plan as u, after putting 600+mi on the Polaris 3in, i don't see the need in swapping it out. Instead, i spent that money on the elevate spindles and TRS /Indy specialties clutching. Those were greater improvements.
Now if this Polaris track falls apart, i will likely put a Powerclaw on as a replacement.
Sent it
looks like the intake is still out the front..... such a terrible design!!!!!!!!!!!!!
- Air box- They sealed it FROM FACTORY! They also added 2 frog skin vents near the front nose, my dealer had been suggesting it for years, makes a big difference in the powder. Used a rubber tape like deal to seal intake
- Carbon fibre Torque link
- Sturdy tunnel, not so thin like the 18/19s
- You can now get a quad wheel kit, (from shuswap Xtreme) supposed to flex slightly less in the rear end, extending track life
- Cable routing, heat wrapping, overall product finishing is much nicer from what I could see. Colour in person is way better than the awfull release photos
My 21 has the silicone dampers and heavier gauge springs and still broke one at 229 miles.Check out that sealed air box, noticed they also put silicone dampeners like the blast 400’s have on the Y-pipe springs
I do a dab of high-temp RTV gasket maker on all my exhaust springs. Seems to be working at 1500ish KmMy 21 has the silicone dampers and heavier gauge springs and still broke one at 229 miles.
Guys complaining about snow on running boards: it can always be better, but I had to ride my 2005 M7 last weekend with full boards. Fully reminded me how good we have it now.
Some dealers were able to order basically this same sled as a floor model for 2021. My local dealer got 2 or 3 of them.Euro model.. Long cooler, 2.6 lug, estart, NO ALPHA
I have a 07 M and it's a huge difference from my Alpha, but sitting in the shop yesterday I measured belly pan clearance and the M has more. My point is if AC would have extended spindles, changed boards and fixed that snow flap rear bumper mess for the Ascender chassis they would have sold a lot more sleds. Look what Polaris has done with the Matrix (non slash) new plastic new fuel tank narrower rider position cut tunnel. Same as Cat did with the Ascender. Now everybody says Cat is riding on the same 2012 chassis while Polaris has this new wonderful chassis and really its an Axys with new plastic. Now with all that being said if I were buying today I would be looking real hard at the Slash this after years of bleeding green. No matter what we ride now it is a whole bunch better every year.Guys complaining about snow on running boards: it can always be better, but I had to ride my 2005 M7 last weekend with full boards. Fully reminded me how good we have it now.
Not sure we're talking about the same thing, but my old EDGE has coolant through the running boards. Snow eliminators really helped, but still in some conditions and temperatures, those things are just slush magnets. Nice that it'll all melt if you let it idle long enough, but a few minutes of playing and they're packed up again!Guys complaining about snow on running boards: it can always be better, but I had to ride my 2005 M7 last weekend with full boards. Fully reminded me how good we have it now.
Nothing on the matryx slash is even remotely close to cat asceder chassis. Taller, narrower, shorter better designed tunnel, more power, a thing called fit and finish. Better boards, better gauge, storage, belt holder, estart with 11 gallon tank, waaay lighter plus waaay easier steering. Cat has better traction but polaris jumps up on top of snow and goes quicker than any and i bet the matryx is another level above what I'm comparing it to. My alpha also uses more gas and oil than the polaris. At least a gallon or 2 more fuel. Sad to see my alpha go but I'm riding a boost next year.I have a 07 M and it's a huge difference from my Alpha, but sitting in the shop yesterday I measured belly pan clearance and the M has more. My point is if AC would have extended spindles, changed boards and fixed that snow flap rear bumper mess for the Ascender chassis they would have sold a lot more sleds. Look what Polaris has done with the Matrix (non slash) new plastic new fuel tank narrower rider position cut tunnel. Same as Cat did with the Ascender. Now everybody says Cat is riding on the same 2012 chassis while Polaris has this new wonderful chassis and really its an Axys with new plastic. Now with all that being said if I were buying today I would be looking real hard at the Slash this after years of bleeding green. No matter what we ride now it is a whole bunch better every year.
I know u have both, i also have both and i have to disagree on some of this.Nothing on the matryx slash is even remotely close to cat asceder chassis. Taller, narrower, shorter better designed tunnel, more power, a thing called fit and finish. Better boards, better gauge, storage, belt holder, estart with 11 gallon tank, waaay lighter plus waaay easier steering. Cat has better traction but polaris jumps up on top of snow and goes quicker than any and i bet the matryx is another level above what I'm comparing it to. My alpha also uses more gas and oil than the polaris. At least a gallon or 2 more fuel. Sad to see my alpha go but I'm riding a boost next year.
