I know this a mountain forum but this sled was built for trail riding. There are 600,000 registered sleds in MN,WI, and MI. More in these three states then all of the western states combined Polaris is a corporation they think money first. Just not enough market for 3/4 mountain sled at $5000 price tag.
Pretty lame thou for the sled not be efi this day and age thou.
The not enough market for a 3/4 sled was one of the talking points every time I bent someone's ear from Polaris at a snow show or new model release get together.
The cost of research, development, and tooling to do this may very well be the reason we will not see a true 3/4 sled.
However this does not change the fact that they have parts on the shelf (Axys Pro RMK) that can be used to bring an EVO RMK PRO to market that is in the mid 300 pound range.
The answer I have received that the light weight parts are very expensive is a cop out when you consider that using these parts requires no added R & D / tooling costs to bring this sled to the consumer. All the research and development costs as well as tooling for these parts has already been realized. Increasing the volume of usage will bring the cost on these parts down for the 550 RMK as well as the 600/800.
The mountain segment is all about weight, power to weight, the effort needed to dig out a sled, and the effort needed to maneuver a sled. The light weight stuff has been marketed as a premium very successfully for some time now, but at some point it needs to be standard issue for all RMK sleds.
The concern over build volume needed should only be a consideration if they were on the hook for a complete new model with R&D and tooling costs to recoup, and using existing available parts should exclude this factor. Polaris has shown they are more than capable of limited builds thru the snow check program. The non shelf parts I see needed are as follows.
New technology version of the 155 track in a 136,141,or 144 what ever is determined to be the best choice. (The 141 1.6 cobra is already available @ 41 pounds if you don't want to pay for tooling for a new light weight track), smaller tank/ lower seat (already available from the new EVO), narrow light weight A arms (these could also be sold as an accessory to fit the full size RMK for those who want to narrow up their ride/ or cut a deal with an aftermarket company that already makes them), new shorter rails to use with the existing RMK skid (current skid can be shortened to 141 without rear arm relocation), new tunnel to fit the new track length (there may be one available already being used on another 550 model, or just add an extension to the new EVO tunnel and provide for RMK style running boards), New quick drive sprockets for needed gear reduction(existing belt could be used if a belt tensioner is installed).
I am sure there are a few more new parts that would be needed but I still see this as using 95% off the shelf parts to build an EVO PRO RMK. Build only enough sleds to fill snow check and do not push sleds on the dealers they do not think the will be able to sell.
Set a base price near the trail EVO and offer snow check options to get this sled to the mid 300 pound range.
If the 3/4 size RMK sled everyone is asking for but just cant be done due to low volume mathematics then do the next best thing with what is available.
I have cringed on several occasions when I have had dealers tell me how so many are putting 10 year olds on a 125 HP 600.
The first MFG to offer a sled to fill this void will most likely own the market and also start the brand loyalty with the kid ridding it that will sell sleds in the future.
Even if the margins are low someone should acknowledge that sometimes you have to invest into the future to succeed in the future.
Polaris are you reading this.
