Huh, I've wondered about SPI's fix kit. I've got SPI hyperdrive pistons on my long-rod 800, and it's run strong for at least 300 miles now. I haven't peeked into the bores lately; I need to do that, I suppose. What version of SPI pistons were you running on that? Hyperdrive is a different alloy - maybe hypereutectic? But a lot of cast pistons are actually hypereutectic these days - I think including most OE two-stroke pistons. All I can find is "HyperDrive Piston line is made from a space-age aluminum alloy which maintains it's high tensile strength up to 7000F (3800C), 50% higher than a conventional cast piston." I'm not sure how it maintains its strength at 4500F over the highest melting point of ANY aluminum alloy, so that statement is pretty useless other than (hopefully) meaning it is a stronger alloy.
After seeing marring to the freshly-plated bores from forged pistons (Wossner - I've heard it's not uncommon, and "not a problem," but if the cast pistons hold up and don't do it, that's a no-brainer), I'm sticking with cast, and preferably OE. That's what's going in my 600 when I get a chance - those are still Elko, made in Austria, and if that's the case with the OE 800 pistons, I'd say it's worth the money on a fresh build (long-rod, if cost is no object). I just didn't want to spend twice as much for OE pistons with already-marred bores, that's why I swapped to the SPIs. There's a bit of "what I've got is best" in that, I'll admit, but it seems the fix kits are a band-aid - they reduce piston excessive piston rock that wouldn't be there to begin with using longer rods. Anyway, just my thoughts on it; you know more about it than me, Steve. I do think OE pistons are the best quality, but fix kit pistons might last longer, plus it's a harder choice to spend that money when the bores aren't pristine and they might not last any longer because of that.
