The machining is not required on the 09's?
I get mine from a local Bearing distributor for $15 ea.
WOW, thats obsurd! You can order them through your cat dealer for around $30 I beleive the part number is 1602-348, same bearing thats in the 05-06 Diamond Drive. I have a feeling that they may be on back-order though.
The ones I'm getting for $15 are a Japanese made bearing, which should be higher quality than the Chiwanese garbage they come with.
For my 07 M8 I had ordered 55/65 gears from BD-Xtreme and decided on doing the wide bearing after receiving the gears. Ordered the 5203 from a local bearing place and picked it up the next day and dropped the bearing and gear off at a local shop to lathe the gear for the wide bearing. Picking it up the next morning (i work nights) and went to put it in and the bearing was to big??? Started looking and discovered i had a 5302 instead of a 5203 Don't know where the bearing screw up came from (probably me) but it didn't matter at this point anyway. I also noticed they had turned down the gear shaft to fit this other bearing so now the gear is no good. This was Thursday morning and I'm suppose to ride this weekend. I called up BD-Xtreme and told him my dilemma, they didn't have any single gears but he gave me a break for the gear set, new wide bearing, turning down the gear for the wide bearing and sending it over night. I know their super busy right now yet everything arrived today (Friday) and the DD drive is back in and is running.
Thanks BD-Xtreme for the service and helping me fix what was probably my screw-up.
