Stuck choke cable? All plugs soaking wet?
Sent from my PC36100 using Tapatalk 2
We just used the setup on the SLP website for clutching. It worked very well. For some really weird reason I had to drop down to #25 pilot jets in order to get rid of a low end bog. However this was with 34mm carbs. I believe you will have the 38mm carbs. As for jetting I found the SLP specs were quite rich so it took a little time to dial it in. Make sure your belt deflection and the belt to primary sheave clearance is set to specs.
Seeing as how you have the monoblock engine and 1996 was one of the worst offenders for crank issues you should address the oiling problem of the bearings. Split the case and enlarge and chamfer the oiling holes at the very least. Turn up the oil pump setting while you are at it.
I'm guessing around 34 minutes is what you are talking about?
https://www.youtube.com/watch?v=ETtKkha8gE0
I found this a few years ago and kept it. I don't know who wrote it but it has some good info in it. See attachment.
With the 34mm carbs. If you lowered the floats 1mm most of the problems went away.
The 38mm carbs didn't witness the same problems. Pressure check your needle and seats. Check to make sure the chokes are seated.
Your fuel pump may be leaking into the vacuum line.
Good info. Basically what I got from that is "Don't buy a 1996 xtra lite triple!!!" What Do I have? A 1996 xtra lite triple with triple pipes lol.
Should I be scared? Or would a tear down and boring of the pto oil port severely decrease my chance of this thing going kaboom?
I think you would have a pretty reliable engine if you did that. Check or replace that pto bearing too if you decide to get into it.
Good pointers on the XCR motors. I have little knowledge with the XCR's as we normally picked up XLT's and RMK's. I didn't realize they were notorious for being a "bad seed"
That problem would only show up on the cylinder that the fuel pump pulse line is on. The cylinders are separated by seals and all 3 would not flood if you had that problem.
When tuning your needle bright you can use a brass washer for a #3 screw to fine tune the height. The washer is about half a needle height thick. Or you can buy plastic washers from yamaha for 100 times the price.
Soak the carb parts in vinegar overnight, they will be tarnished but clean.
the discoloration in there wont hurt anything. long as they are cleaned out with carb spray, and the jets are cleaned. hold them up to the light and mike sure you can see light through the holes. id clean them up, put in new needle/seats, and run it myself. how do the pistons look with your flashlight up the exhaust ports?
