09 M1000 ski pressure?
Bozarth
Does anyone know what adjustments I can do to the rear suspension to lighten the ski pressure?
There are a few ways to accomplish what you are after. Each way has its advantage and disadvantage. You could loosen the springs or let out air pressure (if floats) on the ski shocks. Loosen the limiter strap, or tighten the spring on the center shock. What one person likes another person hates so just play with it on the snow where you can see what the changes you make do. Just make sure that you make on change at a time so you know what is causing the change.
ski pressure
drill out the two lower holes in tunnel for the front arm, have done this on two m1000s. greatly improves getting up on the snow and way less ski pressure.
Move the engine back about a foot...... OH! Sorry I couldn't resist.. :) Just kidding....
I think you can loosen or tighten your front strap or stiffen or loosen your front shock of the rear suspension.I forget wich way does what but thats how that works.read the owners manual to know wich way to go.
Drill the bottom holes for the front swing arm to be lowered. It doesnt look like there is mutch material between holes but it will hold. Drill her out from the inside and it will feel lighter in the front end. Not like a 1m but better.
