the testing that we have been able to do now has shown the 08 set up we use .used in the 09 doubled the track speed .09 set up over 4000ft in deep snow does not work . on the trail it is a bullet tho.
Im in Revvy next week too.
hoping to meet Al again.![]()
What??? A reverse helix doesn't work in the deep?? I'm shocked!! Looks like we should stock up on parts for our setup for the '09's.![]()
same slope same snow , betwen 6000ft and 7000ft we saw stock sled turning mid 30klm's, our 08 set up turning 100kklms.snow was loose and deep enough to make load testing ,finally.
see ya next week joe , more snow forcasted for today and throu the weekend
dave we will finally be able to approach the secret arms hahaha
was klms . it really pulled down and wouldnt get past the 35klm mark . we put the stiffer sec spring in first and it dropped the temp in the belt a bit , then we put the 42 helix in and we gained some more but not enough , had to be on clicker 5
changed the ramps and the spring in the primary next and that put the clicker on 1 and the track speed at 100klms in the same snow and slope .
clicker 1 would get to clicker 3 as the depth of the snow gets a lot deeper .
this was with uncut valves , cut them and expect to add 2 grs.
stoc spring ran up the trail at 6500rpms
160/320 dropped the trail running rpm to 5500rpm
cut the valves and it drops the running rpm to 4500 as we added 2 grs,
these thigs are fast when you get them corraled .
400klms on this sled
