08 pipe is fine, us higher elev. riders don't have to worry about can issues, my dealer said he don't care what can i run so i left my hps on it
Not sure how "interesting" it is. A silencer is just that - made to make the sled quieter and create a suitable amount of backpressure so the motor will run correctly. It isn't unusual at all for Polaris to use the same silencer over several models and at times several model years, even though the pipes change. If Polaris already had something that would work in their "parts bin", why not use it. The "new" silencer is smaller and lighter than the "stock" 800 one, so it's an improvement in more ways than one.
That said, I'll have my sled in for update in a week and I've got an '07 D7 silencer in the shop, so I'll be able to compare to see if it is the same, has the same part number, etc. It's also possible that the "update" silencer isn't actually what was used on the D7, but rather the new "service replacement" for the D7.
Since the 2009 D-8 suffered from a "heat issue" and I'm assuming the replacement silencer is free-er flowing than the stock D-8 silencer, it just seems unusual that a silencer from a smaller displacement motor flows more than a larger displacement motor???, that's all.
And why use the 2007 model silencer, rather than the 2008 model D-7 silencer???
Just thought it was unusual.![]()
ID - Jim at dyno tech found out that on the cfi 800 a lower compression actually gained hp, proved on his dyno, two different heads, plus Poo factory guys spent some time with him so I think the hp will be ok. also your getting what looks to be a diferent color exhaust spring so it might be a complete kit results thing, just thinking
The heat issue IMO is more related to the single ring piston not transferring the heat to the cyl. wall. The can could be changing the flow characteristics, which was affecting the "bog" or the lean issues.
True on the DTR results, but Jim's comments on the explanation was possible beneficial turbulence from the "top hat" chamber design.
BMP is claiming that the new replacement lower compression head makes LESS h.p. BMP post on here's claiming 148.3 h.p. Dyno graph posted here on SnoWest, BMP thread starter.
Take it for what it's worth.
Didn't hear anything about the exhaust spring.
BTW, are you plugging the exhaust valve purge hoses to eliminate the "emmissions solenoid" that delays the opening of the exhaust valves????
I'm sure BMP says the HP is down with the new head and I'm also sure they have a shiny new head that will "fix the problem".
Honestly, if BMP is claiming 148HP on their dyno "stock" and selling their gains based on that, then it's likely running closer to 152HP. Just my own skeptical experience w/performance shops talking here.....
What do think of the rpm. in the BMP power graph?
To me it looks peak hp. @ about 7600 rpm or less...
It may be true that the new stock head with lower compression will work better for some applications / elevations. However, IMO for HIGH elevations a drop in compression from the original stock head (13.5:1), to 11.5:1 on the new head would not produce the same kind of power as we had in 08-09.
After conversation w/ SLP, their testing has also shown that the new compression was not ideal for high elevations. The SLP head gets the compression back up to 13.5:1. It is also advertised to be a 3 hp gain over the original stock head (which I have not tried), and even more when compared to the new lower compression stock head. FWIW, I was told that switching to a higher compression head (for high altitude), produced the largest performance gain in their testing.
I ride 7k-11k, SLP single w/ intake and clutching for the past 2 years with good results. Ordered a '10 that should be here early next week. SLP head is on it's way and will be installed before it hits the snow. Will post results when the snow flys! Won't be too long now![]()
I ride at 4500 TO 9500 feet this is not good for me why can't we just run the stock head that is on it already. If the one that slp is selling is a stock take off head why not any input.
It seems that my dealer thinks there are two cans for the 800's.
1. A pure SLP can - 6 lbs lighter
2. A Polaris/SLP manufactured can
I was told they lowered the price on the #1 can - $200 (which is the one I opted for) and the #2 can was the $125 one. I don't know, I guess I will find out in 2 weeks when I get it back. I had the mid range bog at low elevation and got the reflash, that's the only problem or issues I've had with the sled. I just want to make sure its fixed for good.
I would like to see what DynoTech Research comes up with for the new update. I might order one of those PCIII's.
