02 edge x 600gauge lights?
ok well now i know that the reverse light will never come on, it wont bother me since its not supposed to anyways :p headin out to the garage to check for the wire on the ignition as far as the premium indicator goes.. thanks again!
well i unhooked my ignition switch and made sure all contacts were clean swapped bulbs around (high beam indicator bulb) since i know that lights up....still no premium light.. i also noticed no difference in performance when i tried reg or premium on the switch when i went for a ride earlier..or is it not noticeable?
you have the main connector plugged into the ign switch but do you have the single wire plugged into it also
where the main harness plugs into the hood harness there is the main plug and there is a seperated plug is that plugged in?
