I would suggest putting the sled on the ground and getting the sled level. Don't change air pressure just set them the same for now and manually level the sled as best you can. Then set your camber at about -1 or -2 degrees at ride height. Also what length are your air shocks? We recommend you run 16.250 eye to eye but you can squeeze 16.5" long shocks in but it will effect negative camber especially at full droop. Our spec for our Exit shock is 16.125 which is the perfect length for this front end. Some of the extra negative camber your seeing could be shock length and drop angle issues. Of course you can run the upper ball joint out as far as possible preferably at least one thread showing after the Nylock to be safe.
Hope this helps you.
Thank you for your response
How am I supposed to get the sled level if the sag on right side shock is 1 cm more than sag on the left side shock? I figured the reason for this discrepancy is that the turbo kit sits on the right side of the sled (more weight there), because the air pressure in both shocks is equal.
I have no idea what length are my fox shocks, how do I check this? But these are snowmobile specific fox float 3 evol r shocks, they should be correct length from the factory, right?
Pics??
tttI do not see any joints binding, please have a look at the pics
When I suspend sled with shocks removed I measured height from the ground to the marked point in blue, it was equal on both sides!
surprisingly when I put back the shocks and removed the motorbike stand (I put them upside down on purpose to be able to easily access the air ports) this blue measurement was still equal on both sides, I am unable to explain that, earlier I spent a lot of time trying to measure everything correctly and figure out why the sled is not level.
But I think there is still some problem, the camber on the left side spindle (left side when looking at the pic) is so much more than the other side, you can see that in the pics. The rods being only place to change camber are absolutely setup equally on both sides, the same amount of threads is sticking out and I measured with caliper tool as well
