D
DynojetResearch
Team Pigeon,
You are able to use the WB2 instead of the Autotune. It is the same raw circuitry inside which will supply you with an AFR and autotuning function, but the WB2 is capable of driving an external gauge - the Autotune is not. It also has an input for another analog signal. This WB2 is meant to serve as a universal standalone monitoring system for individuals wishing to watch the Air/Fuel Ratio their machine - be it an Automobile, Watercraft, Snowmobile, etc .... without needing a PCV for fuel control.
IF you do intend to purchse one of these to pair with a PCV, be sure to include the CAN communication cable and the termination plug in your order -- as the WB2 does not come packaged with these items.
And YES - You can also power up the LCD with a 9V battery and it will light up allowing you to make gauge configuration changes, logging setup, etc... To do this, you would need to attach the Positive 9V terminal to either the red wire in the PCV harness, or the Red wire in the CAN cable running to the Gauge. A small pigtail harness that you create yourself would be the easiest way to do this as Dynojet does not offer any sort of plug in external connection.
~T.J.
~T.J.
