I have a few observational questions if you guys dont mind.
A 2-stroke works via a combination of air and fuel obviously. But they also need the pulse timing of the exaust and its expansion chamber. How do you get around this with a turbo? Wouldnt you bennifit from an exaust designed for the higher volumes of exaust? I mean more air/fuel in, the more that has to come out and the stock exaust is desighed specifically for a certain amount of flow and RPM. Just curious how turbos effect this?
I have built a few Banshee's now and they have a "lightswitch" like powerband that reminds me of a turbo. When they "get on the pipe" the machine comes to life just like a motor does when the turbo spools. If you can tune a carb for this type of powerband I would think the fuel curve would be simular to that of a turbo. On my Banshee's I have used a 34-35mm carb instead of the stock 26mm carbs. I did this to try and get as much air in to the motor as possible at my higher elevation. I run massive carb mount K&N filters to supply the air. To get them to run properly I had to increase my compression, run very aggressive porting, and on my stroker motor I ran AV Gas with the additional aid of a dial-a-jet. On my stock stroke I was able to run premium and no dial-a-jet but the powerband was not as wide or as smooth. Adding the dial-a-jet gave me what i think of as a forth dimension of tuning as it added another fuel circut I could tune with along with the pilot, needle tapering, and main jet. I wonder if adding a dial-a-jet would help in the tuning of a turbo sled in that it would supply the additional fuel needed while on boost but has no effect on the low rpm/off boost fuel needs??
Anyone tried looking into Lectron carbs for running on boost? Didnt have much luck with them on a NA sled as they seamed to fight the pulse but if my suspicions about boost is right and that pulse becomes less of a factor, the adjustability of the lectrons might work very well.
Just thinking out loud. Watching this thread and will be watching the results of the kit closely as I would love to do this to my new sled but not till it is proven. I dont have the time nor the $$ to be someone elses ghiney pig.
i agree on the Lectron Carberators.....as for the exhaust imo on almost every turbo kit sold the stock exhaust has performed very well at handeling the motors harmonics waves under boost. Had the stock exhaust not perfomed correctly the results imo would show itself at the turbo since all turbo's are exhaust driven .
OT
