Along with a 146.I don't think they missed the mark, I think that's what they're going to sell you next year![]()
Hitting the DET sensor on the Poo at 10000 feet, full race, 12.2 afrs, , 10 pounds of boost and 8400 constant RPM. Tried to put a spacer in the sensor, finally ended up unplugging altogether. Called the dealer and they didn't really know target RPMS. I'VE heard 8400, 8350, 8700, etc.... WTH? I'm thinking the 8400 constant is spiking a bit, maybe 8650 and causing the DET sensor to go off.
Also, TDR reeds do not seem to work as well on the 850 as the stock reeds. Makes bottom end much less snappy.
Yes your correct, not the best ride down the trail or in the woops, but holds the skis down in the steep.. I actually wish they would have a quick pin you could install to have no skid suspension.. Never seam to Need any when your in four feet of fresh
No kidding. Ive had Stock skid with stock shocks, stock skid with properly set up Exits, Baker skid with Elkas and Kmod with Foxes. All these on turbo sleds. If you want to keep the nose down hard to beat the Baker. If gets choppy or big wind drifts the Baker almost sent me over the bars more than once. Definitely a purpose built skid.haha . . .until you hit that stump or rock hiding 6" under the surface, then you will LOVE having a skid suspension![]()
What does Tri Citys Clutching consist of ?
Also, of the 3, no question that the 850 trenches in the deep much more than the other 2.
But, I would still want the skinnier Plastics of the new 850 that helps it not wash out on the Steep side Hills.
Still running the stock skid or did you get that Baker installed?
Putting a KMod in my 850 this weekend. Where are you guys riding next weekend? We are headed for Alpine possibly, depending on snow the next few days..
While not perfect, the XM wash is mostly solvable. Skinny boards help a lot. Stock are nearly 10" wide from the tunnel up front. Going to 7.5-8" is a huge help. Skinz helium panels for the plastics.
