H
Holomis International
Hey Guys
Yesterday we finally got our 2007 D7 with the Silber turbo completed and we fired it up. We had 2 leaks on the pressure regulator, one where the gauge goes in and one where one of the big allen screws goes in. So we fixed those and checked everything else and it was all good. So we fired it up again checked everything looked good our A/F ratio was spot on at 14.7 at idle, so we took it for a little test ride up and down the feild out back. We didn't go to hard had the boost turned way down and just did a couple passes. Very happy with it so put it back in the shop to get ready to take it up to a local riding area with some elevation for testing. Came into the shop today and fired it up we now have a very very small fuel leak for the F/P gauge body which we now have to fix. But also we noticed the idle to be a bit high and it was kind of high yesterday as well so we decided to check the throttle cable and we felt it was a bit tight so using the adjuster up by the handle bars we just loosend it off a bit to make sure that it was allowing the throttle boddies to fully close.
So then we started it and it started fine but when we go to give it throttle it dies instantly, on occasion if you burp the throttle really quick you can get it to get some rpm's but then it goes into really high idle and just about shoots across the shop. So we put the black adjuster on the throttle back to where it was originally and now it starts just fine but a fine touch of the throttle and it is dead!!! We cannot get it to run beyond a very, very lumpy idle to the point where it won't light up the box or headlight anymore.
We have a feeling that it is not the throttle cable, and we have a hard time beleiving that it is the very very small fuel drip because it is still showing 42psi.
What are your suggestions?
Thanks
FLM Staff
www.holomis.com
info@holomis.com
Thanks
FLM Staff
www.holomis.com
info@holomis.com
